Combine row in list
I’m quite new to Dynamo so this may be easier than I think. But is there any way to get the result as indicated below?
Hi @Adam_H ,
Welcome to the Dynamo community!
Does something like this work for you?
Hi and welcome! :slight_smile:
Try this:
Hi @jw.vanasselt ,
I would highly suggest to NOT use a method like this.
This approach, for example, doesn’t work with VVHH as input. And also not on other combinations of inputs.
Hi @Daan ,
That is right, but I can’t see or his values are variable.
When they are variable than you are right :slight_smile:
Great! Thank you, this should work.
And I should have been more clear in my original post, yes the values are indeed variable :slight_smile:
