Colums are imported upside down in Tekla
when exporting an IFC file of steel profiles from Revit and subsequently importing and converting it in Tekla Structures, the columns are occasionally output in an inverted manner. This results in the starting point being located at the top and the end point at the bottom.
How can we solve the problem by using Dynamo?
Thank you :slight_smile:
Hello @Revit_User23 and welcome…always best to show an example and what you have tried so far…so please share an image, and a fileset…if you can
The picture shows two columns imported into Tekla Structures. The left one is imported incorrectly, while the right one is imported correctly.
Bild_1
I am not allowed to upload attachments yet so I can’t upload the IFC file generated by Revit.
arhh thanks …is it more a Tekla thing without to be expert here :wink:
you could share a link on webtransfer, fileterans etc, probably it could be the ifc export way from Revit have tried on revit forum ?
Start by building an rvt with two columns, one which tekla imports correctly, and one which is inverted. My guess is there is an aspect to the inverted columns which will inform your progress.
It does seem as if this would be best automated in tekla though.
I uploaded the file on WeTransfer
It’s the same file as in the picture. The larger column (HEB450) is correctly converted, the smaller (HEB220) one is incorrectly converted.
