Hi, I want to minimize the list of rooms, I mean to collect all have server names in the same row and all meetings in the second one.
Try using a filter with something like String.Contains.
As Nick has suggested, you can use a String.Contains node with “server” and another with “meeting”.
You will also have to use a dictionary to associate the actual rooms with their names.
thanks, @cgartland but I don’t want this will explain to you what I mean I just want all rooms in the same list but without duplicating to the start name of rooms like this
What is your end goal? What are you trying to accomplish? This may help us find a better overall solution for you.
ok, my final goal is export layers of rooms to auto cad so I need all room has the same start at the list to keep in one layer so I need all rooms without duplication
My first question would be why are you including a number in the room name when they already have a room number? It would be much easier to just name them “server” or “meeting” and use the room number to differentiate.
I want to convert this list to other
List.UniqueItems will give you the unique values, but I’m guessing you would still want your elements filtered. I’m still having a little trouble understanding exactly what your situation is.
thanks, Nick it’s working finially
