I tried using the Photo.Angle node, but it only return ‘0’ for each photo. The other photo nodes seem to work fine. Is there a setting on the camera that should be toggled for this to work, or is there an issue with the node? Or, am I not using it properly.
Sample photo.
I would like to see the AddHyperlink node expanded to more objects than just Block References. Instead of an input port of “BlockReference”, the input port would be “Object”.
Also, similar to AddHyperlink, it would be useful to have a “AddReferenceDocuments” node.
A node to get the useful range of the specified geographic coordinate system would be a useful addition. This would give us a way to filter out input data that is out of that range and present a message indicating that some data is out of range.
I am using the hatching tool to create a solid pattern in a site plan but for some reason the hatching is showing for only half the hatch area. When I use the same command in Civil 3D for the same object the solid hatching fills the whole object (top object hatch created in Dynamo, bottom object hatch created in C3D. Do you know what might be causing this?
@mbrayN4L27 it looks like I made a mistake and I’m skipping the last vertex in the creation of the boundary of the hatch, I’ll fix it in the next release, thanks
Hi Paolo,
Many thanks in advance for the great work you’re doing developing this tools.
I came across with your videos in Autodesk university about the tunnelling tools, I’m giving them a go, but I struggle to understand how some of the nodes work. Is there any ReadMe, video or tutorial to learn a bit more about them?
Ben
Are there any plans to add the functionality for Pressure Networks, to the toolkit?
yes, the structure is already there but not all the necessary methods are in the Civil 3D API at the moment.
Thanks @benjamin.lafarga at the moment we don’t have documentation. Can you post a question trying to explain what is not clear?
Could you please elaborate on the “AddReferenceDocuments” ?
@safi.hage can you please look into this?
Yes.
