Civil 3D 2026 + Dynamo: Multiple Autodesk Nodes Failing — Likely Civil 3D & Dynamo Version Mismatch
Hi everyone,
I’m seeing widespread failures across several Autodesk Civil 3D Dynamo nodes in Civil 3D 2026.2.2 using the bundled Dynamo. The errors look like internal .NET/API issues rather than bad graph inputs.
A recurring error is (Also PFA SC):
Method not found:
‘Autodesk.AutoCAD.DynamoApp.Services.ObjectDescriptor
Autodesk.AutoCAD.DynamoApp.Services.ObjectDescriptors.GetDescriptorByRXClass
(Autodesk.AutoCAD.Runtime.RXClass)’
Environment
  • Civil 3D 2026.2.2
  • Dynamo bundled with Civil 3D 2026
  • CPython3
  • Packages: Camber, Arkance Systems, Civil Nodes, Autodesk packages
Questions
  • Has anyone else seen multiple Autodesk nodes failing in Civil 3D 2026 Dynamo?
  • Could this be caused by a version mismatch between package DLLs and the Civil 3D/Dynamo assemblies bundled with 2026?
  • What is a stable package/version combination for Civil 3D 2026?
  • What is the best way to identify the conflicting DLL or package?
My current suspicion is version mismatch—possibly packages referencing older Civil 3D or Dynamo API versions. Any known fixes, compatible versions, or troubleshooting steps would be appreciated.
Thanks!
AI disclosure: generated with Codex for ArchiLabs — AI for Revit (archilabs.ai).
Your GetDescriptorByRXClass error is consistent with an assembly/API mismatch: the calling code expects a method that the loaded assembly does not provide. It doesn’t identify which package is responsible. Microsoft’s explanation of MissingMethodException describes this failure mode.
The screenshot shows Profile.CreateLayoutProfile. First check its package/library origin in the node’s help or package information. A package node can call Autodesk’s API internally, so an Autodesk namespace in the exception doesn’t establish that the failing node is built in.
I’d isolate it this way:
  1. Record the exact Dynamo version from About and the installed package versions. Save a copy of the graph and the existing package-path settings.
  2. Make a separate minimal test using a confirmed built-in node that also produces the error. Temporarily exclude only third-party package directories from Preferences > Package Settings > Node and Package Paths, then restart Civil 3D completely before testing in a disposable drawing. Leave the bundled host components in place. The original graph may show unresolved package nodes during this test; that’s expected and isn’t the same failure.
  3. If the built-in test now works, restore the third-party paths one at a time, restarting Civil 3D between tests. That narrows down which package load reintroduces the exception. If it still fails without those packages, investigate the host installation and other loaded add-ins using the full stack trace.
The path-setting location is documented in the Dynamo Primer.
If only this node fails and it turns out to be a package node, its exact package version and support for your Civil 3D release become the first things to check. I haven’t reproduced your installation, so I can’t substantiate a stable package combination or call this a confirmed fix. Could you share the node’s package origin, exact Dynamo version, and whether a built-in node fails in the clean session?
Non-AI response here.
Usually this issue stems from using a package that isn’t supported anymore. Civil 3D 2025.2 forced a deprecation for a LOT of the common packages noted (Civil 3D toolkit, older Camber versions, etc.), so updating to a supported package (newer version of the packages) or an out of the box node (non-custom nodes) things should work out.
