Civil 3D 2026 + Dynamo 2025: I want to know how to Assign a Band Set to a Road Profile View Created by Dynamo?
I am using Civil 3D 2026 with Dynamo 2025 and I’m struggling to assign a Band Set to a Profile View created through Dynamo.
In older Dynamo versions (2024), the Profile View creation node had a direct input for Band Set assignment, which worked perfectly. However, in Dynamo 2025, that functionality appears to have been removed. I have also noticed that many direct Civil 3D nodes have been replaced by workflows requiring 2-3 separate nodes to achieve what a single node previously did.
I was advised that if Band Sets (or other styles) are configured as defaults within Civil 3D, objects created through Dynamo should inherit those settings automatically. Unfortunately, this does not seem to work in my case. The Profile Views created from Dynamo are not taking the desired Band Set.
My questions are:
  1. Is there any Dynamo node available in Civil 3D 2026 that can assign a Band Set to an existing Profile View?
  2. Has anyone successfully assigned a Band Set through Python/API after Profile View creation?
  3. Are Profile Views created through Dynamo supposed to inherit default Band Set settings from Civil 3D, and if so, what specific setting controls this?
  4. Is this functionality simply missing from Dynamo 2025 compared to Dynamo 2024?
Any guidance, workarounds, API examples, or package suggestions would be greatly appreciated.
Not sure what you mean by this.
Is that a Civil3D thing?
Do you have the names or a screenshot of the nodes in Dynamo for Revit 2024?
Yes,
I am talking about Civil 3D Dynamo, not Revit Dynamo.
Do you have any Idea? Kindly let me know.
I am not a Civil3D user, so not able to really
assist from this point on.
PS
Did you have a look at any of these topics?
Thanks for your valuable suggestion.
Actually, I looked. But I did not understand straightforward.
I will look into it again carefully
I would highlight that if this node is a out of the box node(shipped with the software), then this list will likely help to highlight the right new nodes to be utilised instead.
Autodesk Civil 3D 2027 Help | Node Changes | Autodesk
Thanks @Brendan_Cassidy . But the node which I was looking, they didn’t mention any alternate node here in Node Changes.
I was specifically looking for the Road Profile View creation node (PFA) that, in earlier Dynamo versions, included built-in inputs for Profile View Name, Style, and Band Set. However, in the newer versions, Autodesk has reduced the node to only two inputs: Alignment and Location.
My confusion is that there does not appear to be any separate node available to assign a Profile View Name or Band Set after the Profile View is created. As a result, I cannot understand how Autodesk expects users to control these properties in Dynamo 2025/2026.
Has this functionality been moved elsewhere, or has it been removed entirely? If removed, what is the recommended workflow for assigning a custom Band Set and Profile View Name to a Profile View created through Dynamo?
