# Check Subassembly Properties And Delete Duplicate Assemblies
**URL:** <https://forum.dynamobim.com/t/check-subassembly-properties-and-delete-duplicate-assemblies/89900>\
**Category:** Civil 3D\
**Created:** [May 22, 2023, 3:15pm UTC](https://forum.dynamobim.com/t/check-subassembly-properties-and-delete-duplicate-assemblies/89900 "2023-05-22T15:15:16Z")\
**Showing post:** 11
**Author:** ![Drbohlav](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/drbohlav/32/113004_2.png) [@Drbohlav](https://forum.dynamobim.com/u/Drbohlav)\
**Post date:** [June 12, 2023, 7:32pm UTC](https://forum.dynamobim.com/t/check-subassembly-properties-and-delete-duplicate-assemblies/89900/11 "2023-06-12T19:32:50Z")
H @jacob.small and @austin_perigee, to access subassemly parameters you can use workaround if you have corridors in your document. You can use _AppliedSubassemly.Parameters_ node: [Change Subassembly parameter at particular region - #4 by Drbohlav](https://forum.dynamobim.com/t/change-subassembly-parameter-at-particular-region/76604/4)
_[View the full topic](https://forum.dynamobim.com/t/check-subassembly-properties-and-delete-duplicate-assemblies/89900)._
