I have got a problem, I hope I can get some help.
I want to change values of different parameters at the same time and export images.
for example; In each exported image, I want to see that dimensions of all parameters have been changed simultaneously.
It may seem a simple problem but it turned to a big challenge for me, as I can not get the results.
It doesn’t give an error but all the exported images are the same and it doesn’t make any changes.
Actually, it could be run for parameters from one element, but when I select more than one elements, it doesn’t work.
something wrong with the way I used nodes?
@Kulkul actually I have been thinking all the time that my parameters are those appeared in the dimension tab! You mean that, it was a mistake?
I defined the parameters in “add parameters” while creating the parametric families… I checked some tutorials but didn’t recognize any other specification have to set up.
P.S. parameters are for different elements and families. But I didn’t set them to each element separately and put all of them in one list. Is that wrong approach? In such a case how could be solved?
@Michael_Kirschner created the node initially. Some clues on behalf of him could greatly help.
Thanks.
hi @Raha_R I don’t remember exactly how this node is implemented - if it works for a single family instance but not for multiple, then you can map the custom node with parameters names and values set over the list of elements.
I would open up the node and see if the parameter set call is mapped over the list of elements or just applied to one?
Hello @Michael_Kirschner Thanks for your response. Actually, I tried to map it with parameter’s value but I really don’t know where is the problem with my scripts .
I can not find the thread now, it was initially expanded in a post previously.
Thank you @Kulkul, I checked them before. I doubt if “select model elements” could work here properly or maybe the issue is related to somewhere else like the way I used map…
