Hi all,
I’ve been working on a script to update the revision block on multiple drawings at a time using Camber nodes and while the script works as intended the text is not aligned as intended
As you can see the text is all over the place.
Is there a way to adjust the text options of the block?
Thank you.
See my script below.
