Is there a way in dynamo to center a object you have it find on your monitor like navisworks is able to do? And grey everything else out too??
- Select the node that create the object
- Switch to Geometry View (by selecting the option in the right click menu or by clicking the button at the tp right of the canvas)
- Select Zoom to Fit from the right click menu
More often than not the selected geometry will be centered on the canvas
Sorry, what i meant is for the element I created in revit. How do I get revit to center the newly created item on screen?
Expand the output of the node and click on the green label with numbers. You might have to scroll a little bit right.
