CeilingPlanView.ByLevel Bug?
Can anybody explain why the graph in this picture only works when using the top method with the Levels node, but not when using the bottom method? The bottom method leads to a program hang every time.
Works for me
Interesting…I’ll have to try this without any packages installed to rule out a compatibility issue, even though I believe these are all default nodes.
So it works for me if I set the graph to run manually, but it hangs when it it set to automatic.
Just checked and have the same issue in Automatic mode.
You could report the issue here
Thank you, Vikram…I will do that!
