I downloaded a small dynamo example, but I get the error in the picture attached and I do not know how to fix it. I did not find error similar in the forum
Can you help me please?
Looks like you may be using an older version of Dynamo. Update to the latest and see if that gets resolved.
Thanks @jacob.small for the quickly reply
I’m current using the version in attached picture. I run in revit directly.
Which build of Revit?
I have revit 2019.1
You’re missing one year’s worth of updates. Update to 2019.2.2 and Dynamo 2.0.3 and see if that solves the issue.
Note that with Revit 2019.1 you are not going to be able to access any autodesk services which interact with the web due to missing security updates. You may want to review this page: Autodesk Transport Layer Security Updates Require Revit Security Fix
The above screen shot seems to be from Dynamo Sandbox.
Here is the same screenshot I get in Revit 2019 with Dynamo 1.3.4 ( Ido have 2.0.3 installed as well, which is triggering the “up to date”. But your original screenshot definitely seems to not be from Revit)
Can you post a screenshot of your library for us?
I fixed the issue by installing the new version 2.03
