Can't add filter rules with FilterRule.ByRuleType
Well, @Ben_Osborne posted solution on the other thread is the same approach as mine.
here is the python code is you ever want to reference it:
# Import RevitAPI
clr.AddReference('RevitAPI')
# Import ToProtoType, ToRevitType geometry conversion extension methods
# Import DSCore nodes in Dynamo
clr.AddReference('DSCoreNodes')
import DSCore
from DSCore import *
# Import python library
import sys
pyt_path = r'C:\Program Files (x86)\IronPython 2.7\Lib'
sys.path.append(pyt_path)
import os
import shutil
import math
# Import math library
from math import *
#Import Data and Time
from datetime import datetime
now = datetime.now()
#Import System Library
import System
from System.IO import Directory, Path
app = uiapp.Application
def ToList(x):
	if isinstance(x,list): return UnwrapElement(x)
	else: return [UnwrapElement(x)]
names = ToList(IN[0])
cats = ToList(IN[1])
catids = List[ElementId]()
catids.Clear()
for cc in cats:
	catids.Add(cc.Id)
Parafilele = []
#get parameter id via name
iterator = doc.ParameterBindings.ForwardIterator()
while iterator.MoveNext():
	if iterator.Key.Name == "123":
		pvp = ParameterValueProvider(iterator.Key.Id)
		break
#def subsubset of element filters
ssfilters = List[ElementFilter]()
ssfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringBeginsWith(),"test1",False)))
ssfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringEndsWith(),"test2",False)))
ssfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringLessOrEqual(),"test3",False)))
ssfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringGreaterOrEqual(),"test4",False)))
#define subset of element filters
sfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringEquals(),"hello1",False)))
sfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringContains(),"hello2",False)))
sfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringContains(),"hello3",False)))
sfilters.Add(ElementParameterFilter(FilterStringRule(pvp,FilterStringContains(),"hello4",False)))
sfilters.Add(LogicalOrFilter(ssfilters))
#define final set of element filters
fRule = LogicalAndFilter(sfilters)
for name,cat in zip(names,cats):
	paraele = ParameterFilterElement.Create(doc,name,catids)
	paraele.SetElementFilter(fRule)
	Parafilele.append(paraele)
#Final output
OUT = Parafilele
And i believe there are lots of custom package out there that can and will extract shared parameter id.
and also, i dont get what you meant by this?
Do you mind elaborating it?
I actually can’t set either of my values right now. I’ve tried both the string “Yes” and a boolean. I don’t know why the workset one isn’t working because I’ve been able to get the value to work when making another filter for demo.
I haven’t had a chance to look at your code in detail yet, I’m probably going to do this after this post. I noticed your loading a lot in. Is it all needed or is it just your standard module loading in Dynamo?
Is the parameter you are trying to set a Yes/No parameter?
If so, use Yes = 1, No = 0.
Yes, but when I use 1, FilterRule.ByRuleType doesn’t work.
Not sure if this is the problem, but might the problem be the Rule Type inputs? I don’t know because I have never used the nodes for filter creation but it’s worth a shot.
any, sorry for the late help. But if you wanna filter boolean type of params, here the code below to do it.
	if iterator.Key.Name == "boolean":
		break
#Empty list of Element Filter
sRule1 = ElementParameterFilter(FilterIntegerRule(pvp,FilterNumericEquals(), 1))
#Get a list to cat ids to be used by the filter
catids.Add(Category.GetCategory(doc,BuiltInCategory.OST_Floors).Id)
#Create the ParameterFilterElement
pfe1 = ParameterFilterElement.Create(doc,"Example view filter1",catids,sRule1)
#Final output
OUT = pfe1
