Hi, I couldn’t use the Curve.SplitByPoints function as I did in Python
can anyone tell me what library should I reference in C#?
Thanks in advance.
Thanks in advance.
Hi there
You might be able to check the content of the OOTB nodes by using a .Net decompiler and assembly browser such as jetbrains dotPeek.
Link: dotPeek: Free .NET Decompiler & Assembly Browser by JetBrains
Are you are looking for the Autodesk.DesignScript.Geometry library? That’s located in ProtoGeometry. You can find that here:
With this you can create and modify geometry in C#:
using Autodesk.DesignScript.Geometry; //this is optional but will save you some code writing later on
Autodesk.DesignScript.Geometry.Curve example;
example.SplitByPoints(); //put points here
