Hi all, I’m new using Dynamo and I’m trying to create a polygon, but the options that I get from the geometry menu for polygon, are these:
But I do not see the option of creating a circumscribed polygon, does anyone know how to do it?
Hi, take a look at the SpaceLayout package
Hi Yna_Db, thanks, Already download the package you told me, but which option you use to make it circumscribed, because there is no option for that.
And that’s what you said when you said it does not work for you?
Hi Viktor, thanks, I’m going to try it, thank you very much for your help
Viktor if it is not a problem you could send me or post the code, is that in this image I find it difficult to see well as far as the connectors.
This is my email arsa1407@gmail.com
Thank you.
Thank you very much Viktor
You could also try this
It is based on the formula for the Side of the Circumscribed Regular polygon. Appologies for the bad formula definition, it is not the best definition but it works. It is possible to add everything in a Code Block but it is still working like this.
Thank you very much Petar
Finally didn’t work well with the Space Layout nodes, I did it following the same idea and @Thomas_Mahon suggestion:
