Dear Experts,
I need your suggestion. I am planing to prepare script to make some calculation according to user inputs. For example:
Calculation of Flow rate through pipe
Inputs are:
Density of water
Cross section area
Water Velocity
Output is:
Mass Flow Rate.
I made some survey.
Using UI.MultipleInputForm nodes it is impossible to input integer or number. It only lets us to input string. Please help.
If not, you can split the string by e.g. a comma first and then use the same node on each set of value and use a little simple math to connect the final number, otherwise a few lines of Python can also do the job.
