Has anyone calculated the slope of a Curtain Panel? Probably the panel would be hosted in Sloped Glazing. Just wanted to ask first before re-inventing the wheel.
Is the formula simply ?
Calculate the angle of inclination (with respect to a direction/vector) and then convert
Here is a quick crude work flow…
Vikram
Maybe I misunderstand-but doesn’t using Vector.XAxis means that it only works if the curtain panel is perpendicular to X axis ?
In other words- if the panel is rotated about Z axis- the angle between the 2 vectors is incorrect
Andrew
That’s what I was thinking. I think we need to get an individual panel’s vector along its Height direction but horizontal. We can get its outline and then I suppose it’s the second line of its rectangle.
yep, that does it
thanks Vikram
