Hi All,
I have spent more time than I care to admit on this.
How can I get a TaskDialog.Show to show my entire list for ViewPlan.Name?
I am using the builtin MacroManager, SharpDevelop
* Created by SharpDevelop.
* User: aclarke
* Date: 9/23/2019
* Time: 10:07 AM
* To change this template use Tools | Options | Coding | Edit Standard Headers.
using System;
using Autodesk.Revit.UI;
using Autodesk.Revit.DB;
using Autodesk.Revit.UI.Selection;
using System.Collections.Generic;
using System.Linq;
namespace MyTools
[Autodesk.Revit.Attributes.Transaction(Autodesk.Revit.Attributes.TransactionMode.Manual)]
[Autodesk.Revit.DB.Macros.AddInId("68646703-C7DA-4901-AC25-1A5C77654362")]
public partial class ThisDocument
private void Module_Startup(object sender, EventArgs e)
private void Module_Shutdown(object sender, EventArgs e)
#region Revit Macros generated code
private void InternalStartup()
this.Startup += new System.EventHandler(Module_Startup);
this.Shutdown += new System.EventHandler(Module_Shutdown);
#endregion
public void CreateSheets()
//Current Document
Document doc = this.Application.ActiveUIDocument.Document;
//Build Collector
List<ViewPlan> collectedViewPlans = new FilteredElementCollector(doc)
.OfClass(typeof(ViewPlan))
.Cast<ViewPlan>()
.ToList();
List<String> strViewPlans = new List<String>();
foreach (ViewPlan vp in collectedViewPlans)
strViewPlans.Add(vp.Name);
//strViewPlans.Append(vp.Name);
//TaskDialog.Show("Title", vp.Name);
TaskDialog.Show("Title", strViewPlans.ToString());
