I have created a Dynamo script to obtain the subtraction of a solid with other solids and, afterwards, to send it to a FamilyType.
The TPF-ObraEntrada.rfa family that I obtained seems to be glitched. The solid obtained is missing a face:
Here is an image of the original solid before the subtraction, next to the glitched solid obtained from Dynamo.
Any ideas on why could this be happening and what to do about it?
Any help would be appretiated.
Kulkul
December 4, 2018, 10:50am
2
Hi @RitaAguiar
Could you please circle which one is glitched and the original solid and also drop relevant files here. It will help others who is trying to help you.
Kulkul
December 4, 2018, 10:58am
4
I think it has to do with your material pattern or Model Display Settings.
Thanks for your reply @Kulkul
I’m not sure about it, but I really think the face is missing. When I select the model it still shows a black void where it should be the face:
and when I render the model the shadows go inside the structure as if really there is no face:
Kulkul
December 4, 2018, 11:51am
6
Could you drop rvt and dyn file here?
@Kulkul
I could not upload the whole file here so I put it in the cloud.
https://1drv.ms/f/s!Ai2hypH4bi73jhp8hbPJi-h1jQI_
Kulkul
December 4, 2018, 2:37pm
8
Looks like it’s a graphical issue. You can ignore this as far as it’s returning complete geometry. If you don’t like then you can create 2 families. Check this one out https://drive.google.com/file/d/1CJDGEiz7GpYIrcHp9i9IORKCTN6E2FUh/view?usp=sharing
Condutas3 for rita.dyn (30.5 KB)
Thank you very much for your help @Kulkul !
