Hi everybody. I could not run the BoundingBoxIntersectsFilter command in the Revit API. Has anyone experienced this before?
You are not creating an Outline object
Try this on line 45 myOutLn = Outline(XYZ(0, 0, 0), XYZ(100, 100, 100))
You could also clean up the imports above as you are importing some things multiple times and others are not required
Its working, thank you Mike
