I now want to run this on multiple Revit Project files using Bird Tools Multiplayer to delete specific parameters from each one… I have gotten it to work some of the time, but most of the time I just get this from the MultipleInputForm:
Sometimes it shows the parameters and allows me to delete, sometimes it doesn’t and I cant understand what the specific issue is? Can anyone offer some advice or suggestions about this issue?
Thanks!
My guess is that the multi-player is getting out of sync with the UI nodes… Might be better off populating the list of parameters to an external file in one graph, having the user decide which to delete in that, and delete the parameters in a second graph.
Thanks for the responses!
What I cant understand is why it works sometimes, for example I have successfully done this with user inputs about 10 times, its just very inconsistent. @jacob.small when you say populate to an external file, do you mean to something like an external text file?
Ahh I see, thanks Jacob!
I am trying to get a little greedy and do this without having to open the files individually (As that is what the request was), but if that is not really going to work, at least I know that.
Thanks again!
There is no way to get into a file without opening it.
Bird tools does it for you in sequence, but it’s still opening everything.
If you want to circumvent manually opening the files, utilize a Python node to do the work for you. Reading parameter names is pretty straight forward, and populating the output file is easy.
Deleting parameters isn’t something I’ve done, but I’m guessing it’d be pretty straight forward (well assuming you’re ok with losing all the data contained therein - I certainly wouldn’t be).
Give it a shot and if you get stuck start a new post providing the content to reproduce up to where you got to and the community can help out.
Appreciate that Jacob, thank you.
If the need to background open is a necessity for them, I will try and put some Python together and post here if I get stuck.
Thanks again!
