Beug?
#1
Hello
I have something strange with list.uniqueItems
thinking it is a bug…
there is no way to have a normal result on this code block
#2
What is generating the number? Sometimes rounding makes them appear the same but actually they are not for items like points or point coordinates.
Hi @Lalicorne
Try converting it to integer and see if that makes any difference. You can add this inside code block to convert to integer:
n:int[]
#4
You can also use a Math.Round function to ensure that the values are ‘cut off’ at a reasonable degree of precision.
it’s a .X coordinates from points
still not working with an int64
#6
working fine now…
thanks a lot !
don’t understand why math.floor didn’t worked…
#7
It didn’t work because your value was rounding up initially, but down with floor.
