@T_Pover How would i get it to detach from central. And the current graph will upgrade files and save them as the same name. I cant figure out how to detach it and save it as a different name.
Save as Upgrader.dyn (15.0 KB)
Here’s code to detach from and save as a single file where IN[0] is the file location of the Revit file you want to copy:
app = uiapp.Application
# Import RevitAPI
clr.AddReference("RevitAPI")
modelpath = FilePath(IN[0])
options = OpenOptions()
options.DetachFromCentralOption = DetachFromCentralOption.DetachAndPreserveWorksets
worksharingOptions = WorksharingSaveAsOptions()
worksharingOptions.SaveAsCentral = True
SaveOptions = SaveAsOptions()
SaveOptions.SetWorksharingOptions(worksharingOptions)
newdoc = app.OpenDocumentFile(modelpath,options)
newdoc.SaveAs(r'C:\Temp\Revit_temp\newmodel.rvt',SaveOptions)
OUT = 0
@T_Pover Thank you! But How can i make it save in the same location with a different name? I would like to be able to open the first file in a directory, open it, detached from central, save as a different name, and then close the document. Then move onto the next file in the directory.
This script does everything i need but detach and add “v2017” to the back of the name. I just added the highlighted part to show you what text i wanted to add. i know their isnt an IN[4] in the python script.
Alright, this should work:
# Import RevitAPI
if isinstance(IN[0], list):
files = IN[0]
files = [IN[0]]
version = "v" + app.VersionNumber
for file in files:
modelpath = FilePath(file)
newfile = file[:-4] + version + ".rvt"
newdoc.SaveAs(newfile,SaveOptions)
newdoc.Close(False)
OUT = 0
Ill try it out when i get back to my PC thank you!
Are you sure you’re using a central model? The error says it isn’t workshared
@T_Pover Its upgrading right now
if i change
newdoc.Close(False)
to
newdoc.Close(True)
Will it close it after it upgrades and saves?
Yes that will close it, but also save it, seeing as it just did a Save As there’s no need for it to save it again, thus the False value instead of True.
Is it possible to add a the function for going tough warnings/errors like:
And after it is done with upgrading it will put out a log tot the source folder?
I’m new to this all (Dynamo) but looking forward to the possibilities.
Thx all.
the SaveAs method only takes 2 inputs so how could you rename, and save in a different file location?
v = "R" + app.VersionNumber[2:]
jobnumber = IN[1]
projectname = IN[2]
newpath = IN[3]
tOptions = TransactWithCentralOptions()
rOptions = RelinquishOptions(False)
for file in files:
newfile = file[:-42] + jobnumber + " " + projectname + " " + v + ".rvt"
rOptions.StandardWorksets = True`Preformatted text`
trying this script after some time and get the error “Exception: Saving is not allowed in the current application mode.” …what does it mean?
Thank you T_Pover. It works as expected
