AxonometricView.ByEyePointTargetAndElement Size problem
Hello Dynamo Community
I used AxonometricView.ByEyePointTargetAndElement node for this new project i started and when i want to isolate the Element(s) and drag it on the sheet it gives me super big sized crop region. Can you tell what am i doing wrong here? :smiley:
Thanks for the help.
I’m not familiar with the items you’re working with in your model, but this post may be of some use to you.
This was a reply to a previous post of mine, courtesy of @awilliams .
Although this was dealing with the min/max points of an object, it may work better if you feed the min/max points of all the points, find the absolute max/min of the entire list, and feed that into the Bounding Box.
