Automatic mode not updating bug
This appears to be a bug that has existed for a long time in Dynamo. Basically, when making changes, Dynamo freaks out and a node will fail with an error message like “internal error”. Reconnecting the wires retriggers the node and fixes the issue for that node, but not for all others downstream.
In Dynamo 2.18, however, there is no error notifcation. The node just says null. Swithing to manual mode and back to automatic doesn’t fix it. Nor does running in manual mode. The only fix seems to be restarting Dynamo which is a mjor pain.
What causes this issue and how/when will it be fixed?
Would need to see the error to know, but it sounds as if you have corrupted the VM which runs Dynamo and it’s lost it’s connection to some core content. Restart is the fix in such cases. Posting the error, Revit journal, and Dynamo log to the github would be best.
