Automatic Grid,Column, Column name creation
Good afternoon all,i am new to Revit Dynamo, need ur support.
for placing model text on the front and back vertical faces of columns in Revit. The text will be based on the grid intersection name (e.g., N1E1, N2E2), and its vertical placement height will be a user-defined input.Grid and column are placed by using script but facing some issue in placing the Model Text.
Appreciate quick response
Thanks in Advance!
Automatic Grid & Columns.dyn (207.0 KB)
The tiles of your nodes aren’t readable in your screenshot and also it would help if you would pin the preview bubbles like so :backhand_index_pointing_down:.
Example.
Automatic Grid & Columns2.dyn (207.1 KB)
Hello bvs,
with this script attached, i have place column name plate family on the face of the I-columns which is having maximum area, on the front (outer) face it is working perfect, but on the back (inner) surface it is clashes into the column, how to resolve this error, output image i pasted
