If you’re on Revit 2027.3 and Autodesk Assistant suddenly stopped building Dynamo graphs for you, you’re not alone. You’ll usually see one of these:
“Creating Dynamo graphs directly isn’t something I’m able to do for you right now”
“The Dynamo connection is not available in this session…”
IMPORTANT: First, try starting a new chat in Autodesk Assistant AFTER opening Dynamo.
Restarting Revit, Dynamo, or Assistant won’t fix it. The 2027.3 update changed some components that the built-in DynamoMCP and AutodeskAssistant packages rely on to register with Assistant, so the connection never gets set up. The repair below puts compatible versions of those two packages back in place. I’ll update this post when a permanent fix ships.
Who this is for
Revit 2027.3 (27.3.0.28)
Dynamo Core 4.2.1.5887 / Dynamo Revit 27.0.0.5893
You can check these under Revit’s About screen and Dynamo’s Help > About. If you’re on a different 2027 update, don’t force this. Reply here with your versions instead.
The fix
Install 7-Zip if you don’t already have it. Windows blocks the DLLs inside the download if you extract with the built-in tool, and the repair quietly fails. 7-Zip avoids that.
Close every Revit 2027 session.
Download the attached DynamoAssistantRepair-Revit2027.zip.
Right-click the zip > 7-Zip > Extract to “DynamoAssistantRepair-Revit2027”.
In the extracted folder, right-click Repair-DynamoAssistant-2027.ps1 > Run with PowerShell, then approve the admin prompt. The prompt sometimes hides behind other windows, so check your taskbar if nothing happens.
Here’s what the script does, so you know what you’re approving:
It checks your Revit 2027 version and stops if you’re not on the update this repair was built for.
It replaces the AutodeskAssistant and DynamoMCP folders in C:\Program Files\Autodesk\Revit 2027\AddIns\DynamoForRevit\Built-In packages\packages\. That’s why it needs admin rights.
If you’d like to see what it will change before it touches anything, open PowerShell as admin in that folder and run:
.\Repair-DynamoAssistant-2027.ps1 -WhatIf
Check that it worked
Open Revit and start a new project from the <None> template.
Open Autodesk Assistant, then open Dynamo and create a new graph.
Ask Assistant: “Do you see my current Dynamo workspace?” It should tell you it’s an empty, unnamed graph.
Ask: “Place a Watch node on canvas.” A Watch node should show up.
If step 3 fails, Assistant still can’t see Dynamo. If step 3 works but step 4 doesn’t, it’s seeing Dynamo but can’t act on it. Either way, include which step failed when you post.
Still not working?
Reply here with:
Revit, Dynamo Core, and Dynamo Revit versions
Windows version
Which verification step failed
Your latest Dynamo log from %AppData%\Dynamo\Dynamo Revit\27.0\logs. Just the newest file, not the whole folder.
Sorry for the hassle on this one. Thanks to the folks who reported it and helped narrow it down. We have this fixed in newer Dynamo core versions and will have updates when it lands in Revit.
I followed the steps in your post. However after restarting Revit (2027.3) and Dynamo (4.2.1) it failed at step 3. I’m on windows 11. Log file is attached.
Can you provide a screenshot of the assistant’s response?
This line from the log is likely part of the problem, which indicates a possible infosec issue, or that you’ve got a non-standard install path.
2026-10-19 11:14:12Z : at System.IO.FileSystem.CreateDirectory(String fullPath, Byte[] securityDescriptor)
at System.IO.Directory.CreateDirectory(String path)
at DynamoUtilities.PathHelper.CreateFolderIfNotExist(String folderPath)
Can you post your DynamoSettings.xml? Trying to figure out why it’s looking for that folder…
EDIT
Also, check the version of the following DLLs:
AutodeskAssistantViewExtension.dll which should be found at C:\Program Files\Autodesk\Revit 2027\AddIns\DynamoForRevit\Built-In packages\packages\AutodeskAssistant\bin. The File version found in the details tab in properties window should be 0.3.8.0.
MCPExtension.dll which should be found at C:\Program Files\Autodesk\Revit 2027\AddIns\DynamoForRevit\Built-In packages\packages\DynamoMCP\bin. The file version found int he properties tab should be 0.6.2.0.
Let us know if either of those are missing or if the version doesn’t align, both of which indicate the powershell was blocked from completing.
We have this problem here: correct dlls versions as listed above. (0.3.8.0 and 0.6.2.0). We have narrowed it down to a clash with one of our apps: Model metrics: If turned off through the Revit addins manager, all works as expected. If turned on, no link between Dynamo and AI Assistant! Log file attached
Ok - sounds like the powershell was blocked from executing. Kudos to your IT team.
Settings are in %appdata%/Dynamo\Dynamo Revit\27.0.
Might not need to post those though, as I can walk you though the manual repair process here.
Close Revit, Dynamo, and anything else which might be using stuff associated to them.
Download the DynamoAssistantRepair-2027.7z file again (or navigate to it if you have it already).
Extract the contents to a new folder with 7zip.
Open the folder you extracted to and find Revit 2027.3 - DynamoAssistantRepair.7z, and extract those contents to another new folder.
Open the folder you extracted the nested zip file and copy two folders found there - one named AutodeskAssistant and one named DynamoMCP.
Navigate to %programfiles%\Autodesk\Revit 2027\AddIns\DynamoForRevit\Built-In packages\packages\, and paste the two folders in there, allowing write (requires admin) and overwriting the previous files.
Open Revit and start a new project from the template, with whatever units.
Open Dynamo and Autodesk Assistant
Ask assistant “Do you see my Dynamo workspace”. It should reply that you have an empty, unnamed graph.
Ask assistant “Place a watch node on canvas”. It should place a watch node for you.
If that doesn’t work, grab the settings file and send it over.
Honestly it’s a mixed bag… I’ve seen some VERY restricted environments where it’s green lit, and some very open environments where it’s a huge no-no. Basically whatever the infosec team was feeling when they set up it.
For those who can use it, I find this quite functional and well orchestrated.
