Question for the Python gurus. I’m using Dynamo for Civil 3D and I want to replicate the TaskDialog as shown on Kean Walmsley’s blog. Everything is working fine, but I’m not sure how to handle the callback at the end in Python.
Here is the working python code short of the Callback that I need help with.
import sys
# Add Assemblies for AutoCAD
clr.AddReference('AcMgd')
clr.AddReference('AcCoreMgd')
clr.AddReference('AcDbMgd')
clr.AddReference('AdWindows')
from Autodesk.Windows import *
dataEnteringNode = IN
ed = adoc.Editor
td = TaskDialog()
td.WindowTitle = "The title"
td.MainInstruction = "Something has happened."
td.ContentText = "Here's some text, with a " + "<A HREF=\"http://adn.autodesk.com\">" + "link to the ADN site</A>"
td.VerificationText = "Verification text"
td.FooterText = "The footer with a "+ "<A HREF=\"http://blogs.autodesk.com/through" + "-the-interface\">link to Kean's blog</A>"
td.EnableHyperlinks = True
td.EnableVerificationHandler = True
td.CollapsedControlText = "This control can be collapsed."
td.ExpandedText = "This control can be expanded..." + "\nto multiple lines."
td.ExpandFooterArea = True
td.ExpandedByDefault = False
td.MainIcon = TaskDialogIcon.Shield
td.FooterIcon = TaskDialogIcon.Information
td.UseCommandLinks = True
td.Buttons.Add(TaskDialogButton(1, "This is one course of action."))
td.Buttons.Add(TaskDialogButton(2, "This is another course of action."))
td.Buttons.Add(TaskDialogButton(3, "And would you believe we have a third!"))
td.DefaultButton = 3
td.RadioButtons.Add(TaskDialogButton(4, "Yes"))
td.RadioButtons.Add(TaskDialogButton(5, "No"))
td.RadioButtons.Add(TaskDialogButton(6, "Maybe"))
td.DefaultRadioButton = 5
td.AllowDialogCancellation = False
"Need help with the Callback here"
td.Show(Application.MainWindow.Handle)
OUT = 0
Thank you in advance.
