Downloaded, but aren’t these Revit nodes? I’m in Civil 3D/AutoCad…I took a swing at it anyways…if these are the correct nodes, then I’m doing something wrong.
@AdammReilly, If you have the time and if it’s possible, could a node that reads the SheetSet and Sheet unique ID be created easily enough and added to your package?
I can see uses where the unique ID could help Dynamo generate field codes that could then generate some interesting tables or labels that would update on their own as part of a normal regen within ACAD and avoid the Sheet List Table or manually inserting fields.
