How can automatic assign Equipment code to family based building code, level and room number ?
Hi @mohmedsolla. You can retrieve parameter info from elements using the node Element.GetParameterValueByName and set parameters using Element.SetParameterByName.
If you are new to Dynamo or need help setting up, try following some of the tutorials in the Learn tab of this website, towards the bottom of that page.
@kennyb6 Thank you very much for your reply.
Yes, I’m still new in dynamo and I tried but I couldnt, since there are many experts would be anyone shows the direction or example to do it:)
Hope i can get fast reply
Thank you so much
