Any possibility to put analitycal model into adaptive components?
Can you explain this a bit more?
The structural beam/column families are the only ones that have the analytical line functionality built in. Unless Autodesk change the way AC components work and gives them that option, I don’t think it’s doable. What you could do is create model curves that follows your geometry and then export them into a cad file and try to manually import them into your analysis software of choice.
