When you select Nodes and do ‘Align Selection’, is there a way to specify which node is to be used as the Source Node with which to align to? In some other software it is the last object you select.
Seems to correspond to which direction it is aligning to:
Align right -
Uses right-most node
Align left-Uses left-most node
Align top-Uses top-most node
Align bottom-Uses bottom-most node
I can’t believe how much easier it is to get what I want… knowing what you told me.
Thanks!
Also, tap alt, then e, then a, then either T, R, B, or L to quickly open the edit menu, the align sub menu, and chose Top, Right, Botton or Left as needed.
Great! Thanks for sharing!
