Hi can i know the possible way to align UCS to object as in skech. Thanks
The internal origin cannot be moved. You can however draw stuff around the internal origin and then use a Geometry.Transform node to shift content into place at the coordinate system on your curve, disabling the preview of the sketch work around the origin as needed.
