Is there a trick if you added a dll with the Add/Import library button, and when opened on a different computer the nodes show ‘unresolved’ and keep showing that even after adding the dll? It is a lot of work replacing all the connections, and I even suspect some connections are gone…
i faced that issue before, it was solved by importing dll before opening Script.
