In the recent Vasari talk (#29), Zach showed an example of adding levels at an increment. I can do this part. Then he added a level 3ft. above every incremental level, which I'm having trouble doing. As far as I can see, I have everything exactly as he shows it on his desktop, but I'm getting an error under the 'Add' node: 'Malformed addition argument'
Under the console, I'm getting this:
System.Exception:
Malformed 'addition arg': ((10 22 34 46 58 70 82 94 106))
at Dynamo.FScheme.malformed[a](String n, Value e)
at Dynamo.FScheme.op'@364-1.Invoke(Double a, Value _arg1)
at Microsoft.FSharp.Collections.ListModule.loop@144-20[T,TState](FSharpFunc`3 f, TState s, FSharpList`1 xs)
at Dynamo.FScheme.math0(FSharpFunc`2 op, String name, Double start, FSharpList`1 exprs)
at Dynamo.FScheme.Add@378-1.Invoke(FSharpList`1 exprs)
at Dynamo.Nodes.dynBuiltinFunction.Evaluate(FSharpList`1 args)
at Dynamo.Nodes.dynNodeWithOneOutput.Evaluate(FSharpList`1 args, Dictionary`2 outPuts)
at Dynamo.Nodes.dynNode.__eval_internal(FSharpList`1 args, Dictionary`2 outPuts)
at Dynamo.Nodes.dynNode.<>c__DisplayClass1c.<evaluateNode>b__17()
I'm just getting started with Dynamo, so I'd really appreciate some help with this. Here's a screenshot and I've attached the .dyn file. I'm using the latest Vasari and Dynamo release. I've also tried Revit 2014, but get the same result.
Thanks.
