Hi all
This post is related to others i have posted regarding Room Data Sheet automation.
I am coming up against a new issue.
Currently have a project with 2 buildings, each building has approx 300 rooms which we need to populate with RDS data. I have an excel with all the parameters and data that the designers/engineers have filled in. I have been using this spreadsheet to add shared (and project) parameters into the project files. Overall i have a bout 320 custom RDS parameters being added to the project.
The issue i am having is when adding the parameters it will add all the parameters to the shared parameter file, but will only create 90% of them as project parameters. It is random to what parameters are missed out and occasionally it will create all the parameters no problem. I have tried multiple variations of the definition but cant seem to troubleshoot this. (They need to be Shared parameters so i can use our custom tag)
See images for 2 of the variations of the definition along with an extract of 50 of the parameters i am trying to add in the excel file.
Any help would be appreciated
Cheers
