I am using Dynamo for Revit and I would like to know if there is a way to add the parameter propping (distance from the top of the bottom floor to the bottom of the upper floor) to all the columns or walls of a project.
I finally find a way to extract the propping value from the volume of the columns. I am putting manually the columns dimension because I didn’t find out how to get the parameters b and h from the type properties. Any idea ?
It’s interesting that the volume only takes into account the propped height.
Here’s a way that retrieves the area of the columns without having to type a and b values manually. There are probably more advanced ways to do it but i think it’s simple enough and it works.
