# Adaptive component- repeat between XYZ points
**URL:** <https://forum.dynamobim.com/t/adaptive-component-repeat-between-xyz-points/2626>\
**Category:** Packages\
**Created:** [December 1, 2015, 10:09pm UTC](https://forum.dynamobim.com/t/adaptive-component-repeat-between-xyz-points/2626 "2015-12-01T22:09:06Z")\
**Showing post:** 22
**Author:** ![RMohareb](https://sea2.discourse-cdn.com/flex022/user_avatar/forum.dynamobim.com/rmohareb/32/120534_2.png) [@RMohareb](https://forum.dynamobim.com/u/RMohareb)\
**Post date:** [October 30, 2023, 9:30am UTC](https://forum.dynamobim.com/t/adaptive-component-repeat-between-xyz-points/2626/22 "2023-10-30T09:30:02Z")
> [@"BriMohareb\_XXXX" Package for RevitXXXX Thread](https://forum.dynamobim.com/t/brimohareb-xxxx-package-for-revitxxxx-thread/84362/14):
> New Rev 6.0.0 Add Bridge Class with two method [[Automated Linear Structural BIM Model “BriMohareb\_XXXX” package] ](https://www.youtube.com/watch?v=tIeB6t6hn60)[Example.dyn](https://forum.dynamobim.com/uploads/short-url/aizZ6bctmS8YjvgxLYKlUbEsXkU.dyn) (124.1 KB)
> [@Rotate Adaptive 3 Points Family arround X-Axis and Z-Axis](https://forum.dynamobim.com/t/rotate-adaptive-3-points-family-arround-x-axis-and-z-axis/84996/2):
> hi @Cagatay as you host ref. point into the adaptive point to rotat xy plane(about z) you need to add another refre. point to rotat in XZ plan. to calculate the rotation angle use this node from “BrimMohareb\_2023” [image] [Three\_point\_adaptive.rfa](https://forum.dynamobim.com/uploads/short-url/sYZRDp554tYwSMD17HgMARd20uA.rfa) (672 KB) and here is a example
[![](https://us1.discourse-cdn.com/flex022/uploads/dynamobim/original/3X/c/d/cde5a697ea25aca5653050fe1245161d2b5d0f8d.jpeg "Automated Linear Structural BIM Model “BriMohareb\_XXXX” package") ](https://www.youtube.com/watch?v=tIeB6t6hn60&t=146s)
_[View the full topic](https://forum.dynamobim.com/t/adaptive-component-repeat-between-xyz-points/2626)._
