Acquire Type Parameter from Linked Elements
The graph below only works when the parameter is an instance parameter. Any help appreciated.
Hi. Try elementtype + from clockwork…edit bimorph have a node as well link.element.type
Hi, I am actually looking for a Shared Parameter that is also a type parameter and not the type of the element itself. I do not see any nodes from BimorphNodes or Clockwork that does this. But I could have missed them.
Our Mechanical Equipment families have shared parameter SCHEDULE CATEGORY that is used for filtering in the MECH model for creating schedules of Exhaust Fans, Unit Heaters, Terminal Units, ect. I want to create a similar schedule in the ELEC model but as a multicategory so i can compare the ELEC load values of the Mechanical Equipment to the values in the Electrical Fixture being circuited as a placeholder.
I want to use a node to copy the SCHEDULE CATEGORY values from the Mechanical Equipment and apply them to the Electrical Fixtures and then filter the multi-category schedule by the value.
I can accomplish this procedure just fine but only with instance parameters.
