I crash on launch using VM Fusion, windows 7, and dyanmo .8.2. Im going to work on a workaround before posting more but I believe it is a video card issue.
Object reference not set to an instance of an object.
at HelixToolkit.Wpf.SharpDX.EffectsManager.GetEffect(RenderTechnique technique)
at HelixToolkit.Wpf.SharpDX.Element3D.Attach(IRenderHost host)
at HelixToolkit.Wpf.SharpDX.Light3D.Attach(IRenderHost host)
at HelixToolkit.Wpf.SharpDX.DirectionalLight3D.Attach(IRenderHost host)
at Dynamo.Controls.Watch3DView.Attach()
at Dynamo.Controls.Watch3DView.AggregateRenderPackages(PackageAggregationParams parameters)
at Dynamo.Controls.Watch3DView.RenderDrawables(VisualizationEventArgs e)
at Dynamo.VisualizationManager.ClearVisualizations(Object sender, EventArgs e)
at System.EventHandler.Invoke(Object sender, EventArgs e)
at Dynamo.ViewModels.DynamoViewModel.MakeNewHomeWorkspace(Object parameter)
at Dynamo.UI.Controls.StartPageView.OnItemSelectionChanged(Object sender, SelectionChangedEventArgs e)
at System.Windows.RoutedEventArgs.InvokeHandler(Delegate handler, Object target)
at System.Windows.EventRoute.InvokeHandlersImpl(Object source, RoutedEventArgs args, Boolean reRaised)
at System.Windows.UIElement.RaiseEventImpl(DependencyObject sender, RoutedEventArgs args)
at System.Windows.Controls.ListBox.OnSelectionChanged(SelectionChangedEventArgs e)
at System.Windows.Controls.Primitives.Selector.SelectionChanger.End()
at System.Windows.Controls.Primitives.Selector.SetSelectedHelper(Object item, FrameworkElement UI, Boolean selected)
at System.Windows.Controls.Primitives.Selector.NotifyIsSelectedChanged(FrameworkElement container, Boolean selected, RoutedEventArgs e)
at System.Windows.Controls.ListBoxItem.OnSelected(RoutedEventArgs e)
at System.Windows.Controls.ListBoxItem.OnIsSelectedChanged(DependencyObject d, DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.FrameworkElement.OnPropertyChanged(DependencyPropertyChangedEventArgs e)
at System.Windows.DependencyObject.NotifyPropertyChange(DependencyPropertyChangedEventArgs args)
at System.Windows.DependencyObject.UpdateEffectiveValue(EntryIndex entryIndex, DependencyProperty dp, PropertyMetadata metadata, EffectiveValueEntry oldEntry, EffectiveValueEntry& newEntry, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType)
at System.Windows.DependencyObject.SetValueCommon(DependencyProperty dp, Object value, PropertyMetadata metadata, Boolean coerceWithDeferredReference, Boolean coerceWithCurrentValue, OperationType operationType, Boolean isInternal)
at System.Windows.DependencyObject.SetCurrentValueInternal(DependencyProperty dp, Object value)
at System.Windows.Controls.ListBox.NotifyListItemClicked(ListBoxItem item, MouseButton mouseButton)
at System.Windows.Controls.ListBoxItem.OnMouseLeftButtonDown(MouseButtonEventArgs e)
at System.Windows.UIElement.ReRaiseEventAs(DependencyObject sender, RoutedEventArgs args, RoutedEvent newEvent)
at System.Windows.UIElement.RaiseTrustedEvent(RoutedEventArgs args)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputProviderSite.ReportInput(InputReport inputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr hwnd, InputMode mode, Int32 timestamp, RawMouseActions actions, Int32 x, Int32 y, Int32 wheel)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr hwnd, WindowMessage msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndWrapper.WndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam, Boolean& handled)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(Object o)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(Delegate callback, Object args, Int32 numArgs)
at MS.Internal.Threading.ExceptionFilterHelper.TryCatchWhen(Object source, Delegate method, Object args, Int32 numArgs, Delegate catchHandler)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(DispatcherPriority priority, TimeSpan timeout, Delegate method, Object args, Int32 numArgs)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr hwnd, Int32 msg, IntPtr wParam, IntPtr lParam)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(MSG& msg)
at System.Windows.Threading.Dispatcher.PushFrameImpl(DispatcherFrame frame)
at System.Windows.Application.RunInternal(Window window)
at DynamoSandbox.Program.MakeStandaloneAndRun(String commandFilePath, DynamoViewModel& viewModel)
at DynamoSandbox.Program.Main(String[] args)
